Saxo sunroof seal
carl
Saxo sunroof seal
Unread post by carl »
The sunroof seal pops out at the corners every now and again. Should I "glue" it in place with silicone or is there a recommended "fix" for this job. The seal is new I replaced it when I thought it was causing a water leak ( turned out to be coming in under the aerial). The old seal never popped out although this did not appear to have anything holding it in place.
