Hello!
I have a Xsara Picasso with a 1.6 HDi, and I have an EGR issue that I can't seem to get rid of.
About a year ago, I replaced the EGR valve, as it was completely shot. Soot even got up into the actuator, so it could barely turn. Evidently, I messed up here because I did not reinitialize it in the ECU. It worked for a while, but I started getting fault codes relating to it fairly soon.
A couple of months ago, while I did an overhaul of the injectors, I cleaned the manifold as best I could, so there's no blockage there. While I was at it, I checked how the new EGR looked. It was pretty dirty, but nothing crazy, it turned easily. I also tried reinitializing it then with a lexia.
After all that, the current situation is that I often get a check engine light, which goes away after a while, then comes back and so on. The engine runs okay and does not go into limp mode. I have a P0406, a P0490, and a P1162 when the light comes on.
So I suspect there's some kind of issue with the sensor of the EGR. I read that some of the aftermarket ones are quite bad, and I didn't buy the most expensive one, that's for sure. I can't swap the sensor from the old EGR, as the sensor in the new one is different. And I can't swap the whole electronic part of the EGR because the old one is full of soot.
How should I go about diagnosing the issue? should I just get a new, more expensive EGR, initialize it in the ECU and hope for the best?
1.6 HDi P0406/P0490/P1162 codes
Huskyxantia
- x 908
Re: 1.6 HDi P0406/P0490/P1162 codes
Long n short , get quality parts they pay for themselves in the long run initialize it with lexia or what ever else its called pp200 ive had a similar issue with a chinese part 30 quid ish , ok for 4 month then lights back on again , so i purchased a more expensive part no problems at all after .
Husky.
bnorb
What brand of EGR did end up working for you, and how much was it? I originally bought a Loro for about 50 quid. There's a pretty wide range to choose from, I hope I can get away with not buying the 300 quid one from Pierburg
Does 80-100 sound reasonable?
Huskyxantia
- x 908
Mine was about 130£ cant recall the brand was 3 yr ago car sold on and passed mot too as i checked a while after i sold it to which i thought maybe i should of kept it.
Husky.
Huskyxantia
- x 908
Just remembered the brand i got was a Valeo
Husky.
