Hi!
Just wondering how I can figure out the correct length drive belt for my car?
The car motorfactors all list different lengths as "being compatible"...
Thanks!
c5 x7 - what length drive belt?
perrye
- (Donor 2026)
- x 10
Re: c5 x7 - what length drive belt?
It depends on engine, AC or not, tension rollers etc.
Try search here OEM part numbers https://catalogs.ssg.asia/citroen/?lang=en
For example if you have 2.0 Hdi 138
5750 XN DRIVE BELT ALTERNATEUR
K6 - LE 1217
It means your belt is 1217 mm
K6 - LE 1217
- x 6950
Or if you need the correct parts numbers, you may want to consider renewing your parts membership, then pop the VIN up.Agour wrote: 11 Sep 2023, 12:14 Hi!
Thanks!
- x 1061
Can you not see any numbers on the old belt?
Agour
- (Donor 2026)
- x 8
managed to find an older one that fit, which was a 1218.. Fit it and seems fine!
