1.4 vti 207 what best grade oil to go for
harwoodguy
Unread post by harwoodguy »
whats best oil grade should i use
5w30 or 5w40
also read online can use acea a3 or c2 but do you think it be fine even if i used c3 or a5 or a1 or should i strictly pick between a3 or c2
x 6945
Re: 1.4 vti 207 what best grade oil to go for
You need to use the correct grade for the specific engine - it's not a matter of choice when it comes to grade. It's down to engine type and the temperate conditions of the country where the car is used.
We need your VIN first if you want to know which is the correct specification and grade for your vehicle.
Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
