I have just bought a Citroen 2008 C5 X7 with no sign of a replacement CAM belt in the history, so I want to get it sorted out ASAP.
I have been quoted £550 by a Citroen specialist, which I thought was quite expensive; does this sound reasonable?
C5 X7 cam belt
- x 1061
Re: C5 X7 cam belt
Depends, if its a full timing belt kit with tensioners inc water pump & coolant change i’d say it sounds pretty reasonable.
- x 6950
Re: C5 X7 cam belt
Considering the complete original timing kit including belt, tensioner rollers & coolant pump are about £350 for the original parts and about £160 for cheaper approved parts alone without labour, then yes, very reasonable!
c16rkc
- x 104
Re: C5 X7 cam belt
Super - thats good then. I thought it would be around £350... I'm clearly somewhat out of touch!
- x 1083
Re: C5 X7 cam belt
Well it depends if that price includes the tensioners etc or just the belt.
Champion of Where's CitroJim
c16rkc
- x 104
Re: C5 X7 cam belt
I'll double check, thank you.
Re: C5 X7 cam belt
Our Citroen dealer has fixed prices for timing belt £549 for genuine Citroen parts or £450 for 'approved' parts.
I paid £350 the last one I had done at the same dealership.
c16rkc
- x 104
Re: C5 X7 cam belt
Interesting, so dealers charge no more than a specialist garage.
Sadly our local Citroen dealership closed down a few years back. I think the nearest one is 40 miles away now.
- x 6950
Re: C5 X7 cam belt
Now £575 and £455 respectively, as of posting and that includes the water pump.
