2007 Xsara Picasso Blower Wiring
Jimbob 1972
Unread post by Jimbob 1972 »
Hi All.
Does anyone have a wiring diagram for the blower thermister connector (blue 6 pin) to wiring harness please. I need to replace the wire from the connector of the thermister block to the loom back as far back as practical.
A few years ago I changed the blower thermister (blower speed only working on No 4 issue) and its been working fine since. However, recently the fan came loose from mount and the current to that connector (the one accessible from glovebox and inside blower housing (blue 6 pin)) went over and started to melt through wiring harness connector.
Removing the center console surround (radio mount panel) I can see the center vent plastic mounding that looks to be bolted to the cross car beam, but is there an easy way to access the wiring, and/or does it go left or right from there so I kind of know which direction to start stripping.
Any advice would be greatly welcome.
Cheers.
