Hi All,
Had the above fault codes appear this weekend both are local and intermittent faults
P0234 charge pressure regulation
air pressure lower than setting
P0100 Quantity of air greater than the minimum threshold
Kenny
Fault codes P0234 and P0100
KennyW
- x 165
C3 1.4 petrol (SWMBO)
KennyW
- x 165
Re: Fault codes P0234 and P0100
P0100 code will be related to the above
Kenny
Kenny
Reason: Attachment removed as for a different EMS
- x 6950
Not quite the same Kenny, as you have a Delphi Engine ECU, not Bosch, (I've removed that code descriptor image from your post to avoid confusion).
So for your engine:
So for your engine:
| Fault Code: | P0234 |
| Description of Fault: | Boost pressure regulation: Air pressure above the reference value. Conditions for fault: The measured turbocharged air pressure is 450 mbar above the reference value (For 6 seconds). Engine speed between 2000 and 3000 rpm Engine torque below 300 N.m Conditions of activation of the diagnostics The following conditions have to be met: - Engine speed above 1500 rpm - The actual engine torque is higher than 100 Nm |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0100 |
| Description of Fault: | Air flow meter: Quantity of air above the maximum threshold. Description of the diagnostics Possibility 1 With engine speed at 2000 rpm and turbo air pressure at 2 bars, the fault appears if the air flow measured is greater than 1 300 mg/stroke for 2 s Possibility 2 With engine speed at 3000 rpm and turbo air pressure at 2,5 bars, the fault appears if the air flow measured is greater than 1500 mg/stroke for 2 s Conditions of activation of the diagnostics The following conditions have to be met: - Engine speed above 1500 rpm - Battery voltage between 10 and 16 V |
| Symptoms: |
| Suspect Areas: |
KennyW
- x 165
Thanks Marc
darbuck
- x 289
Sounds like a turbo issue Kenny
. I wonder have you a vacuum leak somewhere. Could be related to your bearing noise hopefully not.
Darren
KennyW
- x 165
I've replaced some of these pipes before the only one not replaced is the one going to the turbo. The reason access is terrible. But I do have a new replacement.
Likewise I have replaced 2 out of the three electrovalves which included the turbo EV. The middle one is difficult to reach.
If its the turbo or the wastegate what a pain that would be. The only way would be engine and gearbox out.Major project as you know Darren.
I'm just praying its the FNS wheel bearing being noisy. Had look today and no play in bearing. Also not tyre noise.
The noise increases and decreases with vehicle speed not engine speed.
Kenny
Kenny
darbuck
- x 289
Ah well then it's definitely not the turbo probably the driveshaft bearing if it's not the wheel. Just a thought did you bend the dust guard when you were doing the wheel bearing I nearly always bend them a little bit.it can sound like a bearing. Yes you don't want to be pulling the engine out believe me.
Darren
KennyW
- x 165
I took the dust shield off, so that's okay.
