Hello. I have a Peugeot 207cc GT THP150 with the EP6DT engine and I've just replaced the turbo oil feed pipe. For some strange reason my battery warning light has started flashing amber when I turn the ignition on and stays flashing amber when I start the engine but there are no fault codes. It was perfectly fine before. Any idea what to do without taking it to the garage? I tend to do all the repairs myself.
Thank you
207cc problem
PaulC5
- x 692
Re: 207cc problem
Maybe you disturbed/damaged some wiring/connector when replacing the pipe. The alternator wiring might be a good place to start.
Tiberius
Re: 207cc problem
Thanks Paul. I'll check it out again.
