On my 208 with SMEG only, it gives me the max speed on some ways. You will see this round traffic board on navi display on legt top of the screen
Now, with the 308 ('15) with smeg+ they dont give any maximum speed information. I got a warning on the matrix display with max speed if there are traffic cameras or something. But in other situations i dont see any adviced or maximum speed. Does smeg+ dont have it? And smeg(1st version) have this??
Maximum speed on SMEG+?
- x 6956
Re: Maximum speed on SMEG+?
You probably need to go through and check your POI options to ensure the speed info is displayed. After updating maps, options can reset themselves in some cases.
mikekat
Where exactly is this option in the poi? I checked everything but did not find anything about showing speed.
- x 6956
I was referring to speed limits / zones as part of the danger areas, not the actual vehicle speed. On some systems danger zones are enabled via the POI selection menu as to whether these are turned on or not.
You won't have speed sign recognition on this vehicle I suspect.
