Fuel Pressure Regulator
darbuck
x 289
Unread post by darbuck »
Hi Marc can you give you give me the wiring diagram for the fuel pressure regulator circuit please?
Reason: Moved to the Technical Forum
Darren
x 6950
Re: Fuel Pressure Regulator
There is no specific diagram for the High Pressure Regulator, it is part of the fuel injection system below:
1208 : Diesel injection pump
1321 : Diesel high pressure sensor
1320 : Engine ECU
darbuck
x 289
Ok thanks Marc I should be able to figure it out from that
Darren
