GiveMeABreak wrote: 13 Aug 2023, 21:52
Headlight levelling is done automatically where Xenons are fitted, there is no manual levelling system.
I'm not sure what you're expecting from that list - there's no data there, just a load of headings????
Hi Marc,
I posted those headings because that is all that diagbox is reporting for those 2 entries since it says that it cannot communicate with those ECUs.
Since the power steering is operational and seems to run correctly I was hoping for a hint on where to look to actually figure out why the ECU is not communicating with the DiagBox.
For other issues, for example, the DiagBox reports all the required information:
ABRASR : Anti-lock Braking System (ABS) or Electronic Stability Program (ESP)
Response data
R61FE0000000003830F0409000B1B010F0409FE00000001666721
R6180966654288000039666542880FFFFFFFF0701FFFFFF00
State of the ECU: ESP81
Reference 1 : 9666542880
Reference 2 :
Faults present : 1
P0562 : ECU supply undervoltage fault.
Characterisation : not characterised
Status : Temporary
Variables associated with the fault
vehicle speed : 0 kph
Front LH wheel speed : 0 kph
Front RH wheel speed : 0 kph
Rear LH wheel speed : 0 kph
Rear RH wheel speed : 0 kph
EBA regulation : deactivated
EBD regulation : deactivated
Anti-slip regulation with action on brakes (BASR) : deactivated
Anti-Slip with action on engine torque disconnected (ASR/ESR) : deactivated
Anti-engine brake regulation (MSR) : deactivated
Anti-Slip regulation with action on engine torque (ASR) : deactivated
Electronic Stability Program (ESP) regulation : deactivated
ABS regulation : deactivated
Recirculation pump activated : No
Electric parking brake status : Off
Status of the "assisted holding" function : No holding
Braking status : No braking in progress
Yaw angle speed : 000 °/s
transverse acceleration : -00.1 m/s²
Steering wheel angle : 81.8 degrees
Distance travelled since last time ignition switched on : 195.9 km
supply voltage : 07.2 V
Braking pressure : 00.0 bars
status of the ECU : Main
longitudinal acceleration : -0.08 m/s²
Clutch pedal sensor voltage : Value invalid V
SUSPVAR : Electronically managed suspension
Response data
R61FEFFFFFFFF0661FFFFFF00E00002FFFFFFFFFFFFFFFF667077
State of the ECU: SUSPENSION_ECOTECH
Reference 1 : 667077
Reference 2 :
Faults present : 1
U2005 : triggering (vehicle speed receipt anomaly)
Characterisation : Not characterised
Status : Permanent fault
