Difference between 1.5bluehdi 75 100 130
peugeot01
Unread post by peugeot01 »
What are the differences between the 1.5Bluehdi 75hp 100hp 130hp?
Is it only the ecu tune or is there different hardware?
Also are all the ecus of the three power outputs the same?
thanks :-D
PaulC5
x 670
Re: Difference between 1.5bluehdi 75 100 130
Unread post by PaulC5 »
I do not know the hardware/software differences.
We have a 2019 Peugeot 308sw with the 1.5 hdi 130 hp engine and whilst it is ok, it could do with more power and on long motorway runs the fuel consumption is lower than I would have expected. It would be better with a 2.0 hdi but these have not been available for a few years. It will give around 55 mpg when our previous C4 1.6 hdi would give around 65 mpg on the same 180 mile run between Lincoln and the Lake District.
peugeot01
Yes, at higher speeds the 1.5bluehdi is better under 60mph. After that speed, the fuel consumption just goes up.
The 2.0hdi is so good that the fuel consumption goes down after 60mph :lol:
x 6955
Depends on which engine code you have:
DV5 RE75 PS (55 kW; 74 hp)Turbo-Diesel 16-valve
DV5 RD102 PS (75 kW; 101 hp)Turbo-Diesel 16-valve
DV5120 PS (88 kW; 118 hp)Turbo-Diesel 8-valve
DV5 RC130 PS (96 kW; 128 hp)Turbo-Diesel 16-valve
