I intend to reboot the forum server tomorrow morning (about 7am) following a server kernel update. This should take less than 10 minutes.
I may also take the forum offline in the evening for some server testing (this may be moved to a later date, depending on my schedule).
Forum Maintenance Work 6/8/2023
- x 1481
- x 1083
Re: Forum Maintenance Work 6/8/2023
OH!!! You were the person I might at the pub!! I did wonder what your tag was!
Champion of Where's CitroJim
- x 1481
I happened to be around when the forum was quiet, so have successfully performed the reboot, and have postponed the testing for a few days because I found some other enabling work that needs to be done first.
- x 6950
Thanks Mike, Forum seems to be zipping along nicely at present, despite me having a thumping toothache.
- x 3298
Ouch! Oil of cloves (dabbed onto a finger and then onto the offending tooth) might help with the pain. Paracetamol (which is a pain killer) can also help.GiveMeABreak wrote: 06 Aug 2023, 17:09 Thanks Mike, Forum seems to be zipping along nicely at present, despite me having a thumping toothache.
Armidillo
- x 274
Sorry to be picky, but aspirin and ibuprofen are (non-steroidal) anti-inflammatories, while Paracetamol is a pain killer, but not an anti-inflammatory.Hell Razor5543 wrote: 07 Aug 2023, 01:00... Paracetamol (which is an anti-inflammatory) can also help.GiveMeABreak wrote: 06 Aug 2023, 17:09 Thanks Mike, Forum seems to be zipping along nicely at present, despite me having a thumping toothache.
When I had a dying nerve in a molar (causing quite annoying pain) the only thing that gave relief (well I didn't try the really hard stuff) was sucking a piece of ice, or swilling cold water. Very temporary, as the ice melted and the cold water warmed in the mouth, but it did help me get through until the dentist could get stuck into the root canal.
- x 1481
Re: Site maintenance this week 9/2/2023
I need to take the forum offline to do some DNS reconfiguration.
I plan to do this tomorrow morning (13/8/2023), there will be an outage of up to 20 minutes, some time between 6:30am an 8am. UK time.
- x 8165
Thanks for the warning Mike, an ideal time to do it as far as I am concerned!!
- x 1481
It is a lot easier to schedule maintenance when I am in New Zealand.
- x 8165
The closest you'll get to that this week is New Castle !!
- x 1481
The maintenance is now completed.
