Partner Mk1 Gear Lever bushes
MH123456
x 6
Unread post by MH123456 »
This is just a quick one - what is the part number for the metal (possibly bronze) gear lever bushes where the lever attaches to the selector rod under the car?
The car is a Partner combi Mk1 2001 1.9d. I found a couple of possible replacements for 205s and 206s but no idea if these would fit.
I replaced them with a plastic set I got cheap which obviously worked very well for a very short period of time.
A long time is a lifetime and a lifetime's too short
MH123456
x 6
Re: Partner Mk1 Gear Lever bushes
I replaced the plastc bushes with a bronze set for a 206. Much better but the plastic ones hadn't worn, the nylon nut had loosened, so added a second nut to lock it off.
