I have warnings coming up on Dash which state "SERVICE" and DPF additive too low.Repair Needed.My AutoDiag 600S is giving readings of P1445 and P15B3. Mileage is 117,432. 2011 Plate 1.6Hdi
Exhaust tail pipe is relativitely clean and definitely no excess signs of soot.
Any advice greatly appreciated.
Citroen C3 Picasso Exclusive
- x 6955
Re: Citroen C3 Picasso Exclusive
Please note I have deleted your other post - please don't create more than one post for an issue because it duplicates answers and creates more work.
Ok, so there are 2 things going on. One it is saying that your DPF additive fluid level is at the minimum and needs topping up. Secondly, it is saying that the particulate filter is at or near end of life.
So you will need to have the additive level topped up for sure and also consider whether you are going to deep clean or replace the DPF at some point. Be aware that both these actions will require action using Diagbox / Lexia to reset the additive counter when it is topped up and also when the DPF is cleaned or replaced, that the engine ECU is notified tha tthat the DPF has been replaced.
| Fault Code: | P1445 |
| Description of Fault: | Additive adding: The quantity of additive injected into the particulate emission filter has exceeded the maximum threshold The particulate emission filter must be changed. The volume free in the particle filter is not sufficiently large. Necessary to replace the particle filter at the next service interval. |
| Conditions for Fault to clear: | - |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P15B3 |
| Description of Fault: | Additive adding: Additive level calculated lower than the minimum threshold. The engine management ECU indicates that the additive minimum level has been reached. |
| Conditions for Fault to clear: | |
| Symptoms: |
| Suspect Areas: |
xantia108
Not sure what deleted your other post means but I appreciate the answers.If you are referring to “Service” light , this occurred at the same time as DPF additive low.
- x 6955
You created another post on another thread about the same thing
- x 6955
Yes it will do - the service light is usually put on with these types of warnings / messages, but you have the answers now.
xantia108
Many Thanks.Just hopeful my AutoDiag will reset values.I have one of the Lexia systems on a PC somewhere.(Albeit off ebay but it always worked on my Picasso Xsara and the Xantia. i'll dig it out.
