Heating not working C4 2007
tayyabhashimqasim
Unread post by tayyabhashimqasim »
Hi, I have a Citroen 2007 auto diesel, the heating is not working at all, it turns on but nothing is coming out
I have replaced heater blower motor and resistor however it did not resolve the issue
TIA for your help
x 1955
Re: Heating not working C4 2007
Unread post by Paul-R »
Are you saying that the heater motor isn't working?
x 6950
tayyabhashimqasim wrote: 01 Aug 2023, 12:04 Hi, I have a Citroen 2007 auto diesel, the heating is not working at all, it turns on but nothing is coming out
TIA for your help
But which resistor did your replace? One is the Air Heating Resistor to aid heating within the cabin in colder weather and the other is the Blower Motor Control Module. It is the BMCM that controls the blower Motor itself and if this has failed then either the fan will not work on any speed or will run full blast.
tayyabhashimqasim
Paul-R wrote: 01 Aug 2023, 12:22 Are you saying that the heater motor isn't working?
The heating system & ac does not work on.any setting,
tayyabhashimqasim
GiveMeABreak wrote: 01 Aug 2023, 12:36
TIA for your help
Tried the below parts neither made heater work
https://www.gsfcarparts.com/932pc0570
https://www.gsfcarparts.com/932pc0560
