can anyone help? I have a 306 xrdt '93 and over the past few weeks
the rev counter has taken a while to start working.
at first in was a mile or so , now its about twenty.
when it starts working it jumps up and down usaully reading higher than it should, then once its settled down its fine.
any ideas where to start looking?
306xrdt rev counter intermittant
pash999
rossd
Yep, most likely to be the sensor. Its located on the rear side of the engine, only really accessible from underneath. If you lay underneath the car, look above the diff and slightly to the right, you should see the cable and sensor. Its held in with a plastic clamp and 8mm (I think) bolt. It points to the engine side of the flywheel.
Diesel Power
I think you will find it is the connections behind the counter itself...my 306xtdt had the exact same problem and it eventually stopped working altogether until one day I gave it a slap on top of the clocks and it jumped back into life (for a short while!!), I did take it apart and fix it in the end.
pugxpert
