ESP Disable throu Lexia Citroen C3 2006.
Misha_NS
Unread post by Misha_NS »
Hi everyone,
I have a question? Since the moment I bought the car, I'm having a problem with ESP. The ABS/ESP pump needs to be changed, but I can't find one identical with the same part number. Is it possible to turn off ESP via lexia so that it doesn't give me an error on dashboard, without creating a problem that will affect the car. The car runs without any problems, but that light annoys me.
This is not a final solution, just until I find a pump.
x 1061
Re: ESP Disable throu Lexia Citroen C3 2006.
Unread post by wheeler »
You may be able to un program the ABS/ESP with lexia but it may require you to loop out the CAN lines at the ABS connector.
If you are intending to sort it is it really worth it? if the warning light is bothering you that much stick a bit of tape over it.
Misha_NS
Ok. I thought it was a simpler process. Then I'm not touching anything and continuing my search for the pump. Thank you for help.
