Hi
Wonder if you can tell me power steering is leaking i can see under the car and fluid is going down
is it a replacement pump and a easy job
I'm sure this car is made by the chinese as 29k miles and failing apart
Nemo power steering leak
- x 6956
Re: Nemo power steering leak
Close, it's made by FIAT and built in Turkey.
But as for cost - it will depend on whether it's the pump or a pipe.
ohspecial1
Well as they say
FIX
IT
AGAIN
TOMMOROW
I'm just wondering if its the steering rack
had a look up top cannot see nothing but
when i go underneath can see oil/power steering fluid
FIX
IT
AGAIN
TOMMOROW
ohspecial1
Well the pump is like £80-£100
I reckon the pipe will be way more
Might be worth if i can some how get the pipe off we have a hyrodolic specialist over here so maybe can be fixed or remade
