Hi newbie here. I have been and said hello on my other post.
My wife has a 207cc with an ongoing brake light problem.
The car has at best intermittent brake lights that often don’t work at all.
Have replaced switches many times and often works for a short while but then back to the same routine.
Also sometimes work when you stamp hard on the brakes.
Can anyone tell me if it’s a known problem or a solution? Or suggestions where to look.
Also thanks for letting me join sorry my first post is asking for help.
207cc brake light problem
- x 6955
Re: 207cc brake light problem
There is a problem with some PSA vehicles that result in the malfunctioning of the brake lamps and may trigger intermittently the ABS / ESP warning too. The Solution (where this is the case) involves replacement of the brake switch KIT - so not only the switch, but there is an intermediate harness that goes with it.
So if you have this issue, the switch alone will not fix it. Contact your dealer - there is a technical service bulletin that concerns this.
Sogra29
Thanks. That’s helpful and would also make some senseGiveMeABreak wrote: 29 Jul 2023, 11:26 There is a problem with some PSA vehicles that result in the malfunctioning of the brake lamps and may trigger intermittently the ABS / ESP warning too. The Solution (where this is the case) involves replacement of the brake switch KIT - so not only the switch, but there is an intermediate harness that goes with it.
Sogra29
Done some more research and can see that I can also get the switch with a new loom as suggested earlier so that looks like the next step
Thanks again
Thanks again
- x 6955
Just make sure you have the correct one as there are multiple parts and kits for different vehicles.
