I just discovered that the gearbox oil level plug (2208.48) is rounded off and I will need to replace it.
Does anybody know what are the specifications of this screw ? is it M8x1 fine thread ?
- x 6955
Re: gearbox oil level plug (2208.48)
You have the part number, just order one in from the dealer for the sake of £1.44!
PaulC5
- x 669
A search on that part number suggests a new one is about £1, so I would get the correct one from a Citroen dealer. The Citroens we have owned did not have gear box oil level plugs, only a drain plug and to get the level right you drain out the oil and then fill with the correct amount through a vent on top.
- x 6955
This is for an AM6 automatic, so has a proper drain and refilling procedure.
Sloppysod
- x 386
..... And I was stuck once, couldn't get a Citroën one for a few days, so had a bright idea, the same gearbox was fitted to vauxhalls......... I have two spare vauxhall gearbox level plugs....... 'cos they don't fit the Citroën Gearbox!
Stu
myfirstpicasso
I ordered one from ebay and today I also visited the dealer and they ordered one for me . I will pick it up in the next days.
Maybe I will compare the two parts. But I guess it's always better to get your parts from the dealer.
- x 1064
It's always better for the dealer, not you. Also if it's rounded off, how are you getting it out?
Champion of Where's CitroJim
myfirstpicasso
With a bolt extractor. I just hope it is not Aluminium.
I would first try it on the car . If not , I would try to take the drain plug out and then try to remove the level plug.
In worst case I would replace the drain plug also.
- x 1064
Well whilst your there you might as well replace both, just for peace of mind
