Xantia Brake pedal - getting lower & lower !
trackrod
Unread post by trackrod »
'Have always been happy with my Xantia - until that is, my Son borrowed it for the day. "That brake pedal's a bit low" he said, "I had to feel around before I found the blessed brake!!"
I dismissed his remark intitially (what does he know?) but he's right!
The brake pedal is getting lower and lower. The stopping power still seems OK but the pedal is about an inch lower then the clutch!
I've had a look through the "Haynes" manual for adjustment, but it doesn't even mention the brake pedal height,
Can anyone help with this one????
Homer
x 16
Unread post by Homer »
It sounds like it is in the right spot to me. Are you sure it's not the clutch that has come up?
As far as I know there is no adjustment for the brake pedal.
What does your son usually drive?
AndersDK
Unread post by AndersDK »
The brake pedal IS indeed low - or if you like it - the clutch pedal is high [8D]
That's how it is on Citroens.
No adjustments exists for the brake pedal height.
If the pedal has a long "dead" travel, then it's either the spring pushrod or the brake doseur valve at fault - if not simply the pedal box or chassis.
ItDontGo
Unread post by ItDontGo »
I thought that happened to one of my BXs once. I did have two at the time however and so I may have been mistaking where the pedal was between the two. I had the impression though that I jammed it into the floor one day and it never fully came back up again.
lhm_leak
Unread post by lhm_leak »
I get this problem when my carpeted mat rides up behind the pedals - quite scary when you go for the brake pedal and find it's not there... Something simple like that, maybe?
nick
Unread post by nick »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ItDontGo</i>
I once managed to bend the brake pedal in half on an early BX (don't ask [:I], the steel was quite soft and I've got big feet).
I've never heard of this on a Xantia though, but as Anders says, its perfectly normal for a Xantia brake pedal to be much lower than the other pedals.
Nick
trackrod
Hi everyone - thankyou for the prompt responses.
I've had a second look at the problem - especially the thought that it might well be the clutch pedal that is high.
I don't think so. The brake pedal seems to sit very low. If I lift the pedal there is quite a lot of free travel (upwards!) about an inch and a half.
In reply to Homer - what car does my son usually drive? - answer, anything he can get his hands on!! - but more often, a Renault 21.
Ihm Leak - I've had the same problem with the carpet! 'Bought a new set for the Driver and passenger wells (They weren't Citroen and were a bit too long) Didn't effect the passenger side of course, but often the one on the driver's side would creep up and sit under the brake pedal ! Solved it by slicing off a 2 inch strip.
I'll see if I can find someone local who has a Xantia - just so that I can put my mind at rest. I'll let you know what I find.
np
Unread post by np »
Where is local?It would be good if we knew what area everybody is from,that way sometimes people could get together to compare cars/problems.Except Anders of course!!!
