Citro AX 4Bolts Conversion
gxk69
Unread post by gxk69 »
Hi all,
My AX is 3Bolt wheels from factory and im convert to 4, in front i put all the suspension parts for a Saxo (1.6) and the rear i dont know what drums need to use. Dont want swap all the rear.
Thanks all
x 8457
Re: Citro AX 4Bolts Conversion
Why do you wish to convert from three to four?
I believe four bolt Saxo rear brakes may be sufficiently similar to the AX three bolt so you might get away with just swapping over the drums - which include the hubs and bearings...
Can't guarantee this but worth a look and really, nothing to loose.
