Lack of power
Mistique
Lack of power
Unread post by Mistique »
:cry: For a few days I have had problems with the lack of power in my Peugeot 5008 2.0 hdi. I put the tester on and the following errors appear:
Car Scanner ELM OBD2
DTC report
Selected brand: Peugeot
============1==============
P2562
Raw code: 2562
ECU: Engine control unit
Status: Confirmed
Turbocharger (TC) boost control position sensor - circuit malfunction
============2==============
P107A
Raw code: 107A
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory
============3==============
P1497
Raw code: 1497
============4==============
P2562
Raw code: 2562
And the autopilot doesn't work either. The problem is that no mechanic really knows what to do with it. A little help please. Thanks!!
x 1480
Re: Lack of power
P2562 will be causing it. The 2.0 has a position sensor on the turbo so either it's faulty, or the wiring to it is broken (or the turbo is knackered, but that seems unlikely since it's a circuit fault).
