Electric window switch?
DadOf4
Unread post by DadOf4 »
Hi.
On my RHD C4 the passenger electric window works perfectly from the passanger door, but using the drivers door control it goes down about 75% of the time I tell it to go up. Would this be a new switch on drivers door required. I thought I'd ask as I currently have the door panels off to upgrade my speakers. Thanks.
x 6955
Re: Electric window switch?
Things to check:
1) The wiring through to the driver's side in the door aperture for breaks
2) The Door control panel for the windows and locking / mirrors. Sometimes the plug on the underside can work loose.
3) Try cleaning with electrical contact spray the the board once you separate the connections base from the casing.
