Rear light assembles or lens covers needed for c3 pluriel
arthurnotmartha
Unread post by arthurnotmartha »
Both my rear lens covers have been damage during maintenance. One is now completely missing. The new alternative rear light assembly that is available is not the legal or correct configuration for British roads. Is there a company or manufacturer that can make lenses for both rear lamp assembly's . These are no longer available and have not been made for 3 years. Second hand ones are not readily available anywhere.
Can anyone help with guiding me to lenses or complete assembly's for both rear sides. As soon as possible.
Thank you for this opportunity
x 6957
Re: Rear light assembles or lens covers needed for c3 pluriel
Is this left or right hand drive? Left hand drive versions are still available from Citroen.
x 1454
Unread post by xantia_v6 »
To be legal in the UK, the fog light needs to be on the right hand side, regardless of which side the steering wheel is on.
You can (I believe) get away with a LHD lamp if an aftermarket fog light is added on the right hand side.
arthurnotmartha
xantia_v6 wrote: 19 Jul 2023, 21:33 To be legal in the UK, the fog light needs to be on the right hand side, regardless of which side the steering wheel is on.
GiveMeABreak wrote: 19 Jul 2023, 15:30 Is this left or right hand drive? Left hand drive versions are still available from Citroen.
Thank you for the info it's a right hand drive
