peugeot 3008 2016 central locking fault
JOE+TECH
x 4
Unread post by JOE+TECH »
Hi thanks again for help with the electric door mirror fixed
Still got the problem with central locking not working
Fault none of the doors lock no faults set, looking in parameters on diag tool key is recognised shows doors lock ( but they do not move)
I can actuate the rear hatch and the hatch will open but doors do not
Checked the doors were all closed if I open doors 1 at a time it brings on interior light would indicate doors sending message to bsi
Checked fuse 15 30amp in bsi fuse box all ok
Same VIN if I could have wiring diagram for central locking and some help
ThanKS JOE
x 1056
Re: peugeot 3008 2016 central locking fault
Unread post by wheeler »
Does it not work at all even from the button on the dash?
There is more than 1 fuse involved with the central locking. F2, F10, F11, F14 & F15 (all in the BSI inside the car) are all related to the central locking system. Can you test if you are actually getting power at Fuse 15?
JOE+TECH
x 4
Peugeot 3008 central locking fixed,thanks wheeler your help did the trick
I had checked bsi fuses before looking for help but on your reply you stated all fuses connected with central locking
I decided to double check,All the fuses were powered up with ign on engine running except No2 in the hand book it states not in use
so I over looked no power No2 fuse
After your advice pulled No2 fuse blown ,replaced ( 30 amp fuse) still no power at fuse closed doors pressed lock button on key all doors locked
and mirrors folded in every thing now working
1 why no power at No2 fuse, does it need all doors closed before bsi puts power to it? to make c/ locking work
2 I would like diagram of bsi and c/locking please for future problems, and I could see circuit for No 2 fuse
Thanks again WHEELER for your help
JOE
