PEUGEOT 3008DRIVERS DOOR MIRROR
JOE+TECH
x 4
Unread post by JOE+TECH »
Hi have problem with Peugeot 3008 2016 drivers door mirror and central locking not working
no fault codes present.
1 does it have a door module to work mirror and lock,
2The electric window works
3If I could get some help as to how they are operated and a wiring diagram would be great help
Vin No is VF3**************[VIN obfuscated, can be read by forum staff]
Thanks Joe
x 6956
Re: PEUGEOT 3008DRIVERS DOOR MIRROR
Best guess at this point historically is the wiring between the door aperture which is the weak point due to opening and closing of the door. They often shear and cause intermittent issues with any of the systems like Central locking, windows, mirrors etc.
The systems are separate diagrams, so just check the wiring first as this is likely to be the issue.
JOE+TECH
x 4
Thanks marc for quick reply, I forgot to state I did check the wiring at the door pillar but did not see anything wrong (quick check)
I will have a more detail look to see if I missed something wrong
Still would like a wiring diagram to check power supply to door module ( if it has got one? ) and check the switches on door
Hope you can help ,I think you are correct wiring fault .Makes it simpler if you have something to follow
Thanks Joe
x 6956
Mirrors - from a slightly earlier year:
Central locking is separate from the mirror controls. You don't have electrically operated seats so no memory unit or control for that.
The mirror control is on the keypad for the windows. So check the underside of the control unit as slamming the door heard can dislodge the wiring blocks un the underside - ask me how I know that.
JOE+TECH
x 4
Thanks Marc the wiring diagram I am sure will help me get to the fault
It might be a day or so, to I get back to it
Will let you know how it goes
Thanks Joe
JOE+TECH
x 4
Thanks marc the wiring diagram was great help got the fault
Brown connector inside door corroded
