RT6_READCFG advice needed.
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
mitsub
Unread post by mitsub »
I have installed in one of my previous posts an RNEG2 in my C5(x7) , updated to 2.86 and new maps. All are ok even Bluetooth streaming and phone calls sound excellent, but.... sometimes the radio will not start or it takes a 5mins or so to boot up. I have reinstalled no problem every time. I have attached a txt file from Mirascript RT6_READCFG.
CurrentLanguage:EN
GetHardwareConfiguration:
CFG_HW_BT=PBA_31308
CFG_HW_GSM=NO_HW_GSM
CFG_HW_RADIO=MB500
CFG_HW_FOR_SIRIUS=NO
CFG_HW_GPS=SIRF
CFG_HW_IPOD=FAIRPLAY
CFG_HW_TUNER_ANTENNA=3T
CFG_HW_PREAMPLI=NO
CFG_HW_VIDEO_AUX=NO
CFG_HW_REAR_CAMERA=NO
CFG_HW_FAMILY=RNEG
CFG_HW_AM_TUNER=TUNER_1
CFG_HW_OKI_CODEC=NO
CFG_HW_REAR_CAM_ID=NO
GetSoftwareConfiguration:
CFG_SW_BRAND=PSA
CFG_SW_G2P=OFF
CFG_SW_GPH_DEM=OFF
CFG_SW_PASS_NEAR=ON
CFG_SW_RDS=ON
CFG_SW_TMC=SW_OPTION
CFG_SW_ZONE_APPLI=SW_OPTION
CFG_SW_LOOP_MENU=TRUE
CFG_SW_GPH_BASE=SW_OPTION
CFG_SW_ROAD_BOOK=OFF
CFG_SW_FAST_DR=ON
CFG_SW_AAC=ON
CFG_SW_OGG=ON
CFG_SW_DVB=OFF
CFG_SW_CAN_NETWORK=PSA_2004
CFG_SW_UNUSED_1=OFF
CFG_SW_AVRCP=OFF
CFG_SW_TTS_MODE=WAVE
CFG_SW_POI_SUB_CAT=ON
CFG_SW_FLAC=ON
CFG_SW_ECALL=OFF
CFG_SW_TUNNEL=SW_OPTION
CFG_SW_ALERT_NO_NAV=SW_OPTION
CFG_SW_WMA=ON
CFG_SW_KEEP_OLD_CONS=OFF
CFG_SW_NEW_SPI_PROTO=TRUE
CFG_SW_LIN=1_SCHEDULE_TABLE
CFG_SW_EXPORT_NAV=UTF8
CFG_SW_DIAG_MESS=OFFSET_DISPLAY
CFG_SW_MAP_UPDATE=TRUE
One item worries me: CFG_SW_CAN_NETWORK=PSA_2004
Diagbox is set to canbus 2010 so is 2004 very much similar? Should I change it and it so which one, in RT6_READCFG or on Diagbox?
Also: CFG_HW_RADIO=MB500 is this a manufactures code for RNEG2?
Any help would be appreciated
x 6945
Re: RT6_READCFG advice needed.
There are different versions of the RT6 depending on the vehicle it it going into. There were CAN2010 versions that only went into the later C4, 508, DS4, DS5 and these were not compatible with CAN2004 vehicles like the C5X7, C8, C4 Picasso, 308, 3008 and cars of that year.
Later on, about mid 2012, they developed a version of RT6 that was for the whole range including CAN2004.
Your C5 X7 is a CAN2004 vehicle though, but the unit and software for the RT6 is compatible. So I would leave things as they are if the unit is working correctly.
I suspect your delays and boot issues may be down to the internal MicroSD card which could be failing.
mitsub
Thanks Marc. The MicroSD card is new last week. Do you know what the: CFG_HW_RADIO=MB500 is?
x 6945
No, sorry, not exactly - it's the internal code for the radio.
