Hello all,
Anybody experienced this fault because after clearing this fault later on it appears again.
It is in the BSI 2010
B1808 87 fault in the unlocking of the immobiliser by the ECU
Even with this code everything is working fine no problems whatsoever but still what is this fault and how to solve it ?? Anybody that can point me to the right direction to solve this ??
Peugeot 508 - 2017 - 133kw GT Version
Many Thanks
Matt
MattSVK
- x 3
- x 6955
Re: B1808 87 fault in the unlocking of the immobiliser by the ECU
Basically it's a fault in the unlocking of the immobiliser by the engine management ECU. The engine ECU is not getting the request from the BSI to unlock the immobiliser.
This can happen if the battery has been disconnected without reinitialising the remotes. Try this:
MattSVK
- x 3
Thanks Marc for Your quick reply ... I will try this one that what will happen.
MattSVK
- x 3
I can confirm that the problem was solved after the BSI reset. Thank You one more time!
- x 6955
No problem.
