AD BLUE Citroen relay
Yeet112
New User
Unread post by Yeet112 »
I have a 69 plate Citroen relay with adblue..I am only able to do around 700 miles on a 10l of adblue.No problems with refill etc just burns away well too quick.Is there an explanation to this?I do not aggressively drive. Very often just sit at 65mph.
I see many complaints of adblue lights and warnings but not any that it empties too quickly and help would be greatly appreciated
Many thanks yeet! :-D
x 6945
Re: AD BLUE Citroen relay
According to Citroen, your Adblue tank capacity is 19 litres. This capacity allows a driving range of approximately 3,700 miles (which may vary considerably depending on the
driving style and the type of vehicle). So I'd still say it's a little heavy on the usage as on 9.5 litres you'd expect 1850 miles - and even with the 'varying considerably' factor you're getting less than half that again.
Are you sure you haven't got a leak somewhere? Check near the adblue injector for signs of crystallisation.
