Is it possible to take out the complete headlighthousing?
Ive unscrewed a plasticscrew and i can see that it looks like you can like turn the complete lamp outside.
Is this the case?
Change of headlight bulb
OnlinePaul-R
- x 1939
Re: Change of headlight bulb
On what vehicle?
- x 6945
Be careful as some of these controls are for the headlamp adjustment.sirjonip wrote: 04 Jul 2023, 16:31 Is it possible to take out the complete headlighthousing?
Is this the case?
What is it you are trying to achieve - Ok, I see from the title you are trying to change a bulb - no you should not need to remove the headlamp, and if you do, you may need to have it calibrated again before going on the road at night in case you have completely changed the beam pattern.
