ACCELARATION PEDAL NO POWER WHILST FAN PRODUCING LOUD SOUND
LOVEMORE
Unread post by LOVEMORE »
CITROEN DS4 2012 fan producing loud sound whilst accelaration pedal not responding
whats the cause
x 6960
Re: ACCELARATION PEDAL NO POWER WHILST FAN PRODUCING LOUD SOUND
You'll need to provide fault codes first from a diagnostic - nobody is going to be able to assist you realistically without these.
LOVEMORE
Engine system fault codes
p1336 combustion
misfiring [impact on catalytic converter]cylinder undetermined permanant fault
p1338 combustion misfiring [impact on catalytic converter] PERMANANT FAULT
injector cylinder NO 2
x 6960
... and your VIN please (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff).
x 1011
Unread post by Rp0thejester »
I did have a similar fault, it turned out the air ducting pipe had come undone after the air filter box. Double check the piping. It's probably not the issue you have but worth a look.
LOVEMORE
NOTED WITH THanks, how abt the fault codes P1336 AND P13
38 COMBUSTION MISFIRING
LOVEMORE
May you assist how can l fix fault codes P1336 AND P1338 ON CITROEN DS4 2012
moizeau
x 428
Unread post by moizeau »
You'll need to supply your VIN as Marc requested, fault codes can be specific to certain models/engines.
Pete
LOVEMORE
VIN NUMBER VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN
LOVEMORE
May you assist l m stuck here
