C5 2.0HDI 07, turbocharger fault P0243
toolfan
x 3
Unread post by toolfan »
Hi all
I am new here, looking for some advice. I am an enthusiastic hobby car mechanic, normally working on older cars and bikes. I own my C5 2007 2.0HDI (228'000km) since a few years and did already quite some repairs. I like the car, but sometimes the modern technique is over my know how.
These days I am having troubles with missing turbo pressure. Diagnosed with Lexia, P0243, open circuit to the pressure regulator (the magnetic valve).
- replaced the corresponding valve (behind cylinder bank) - no better
- disconnected and sprayed the electric connectors, shaked all the cables, - turbopressure back to normal (2.3 bar) for some days
- tested the function of the vacum operated turbo-regulator, the rod moves fine when vacum is applied
- when there is low turbo pressure, the air temp intake sensor shows -50°C (changed the sensor, no better)
- when there is low turbo pressure, the tempomat (automatic speed control) is not working, malfunction warning in the dashboard
- engine error light is allways off
I would like to find out, where that circuit is open, but I have no wiring diagrams. Tried to download dockbackup/sedre, but cannot get into any diagrams.
If somebody could send me a print of the engine mangement wiring diagram, would help me a lot! Or tell me where to start checking... ;)
Looking forward to the advice of the more experienced French Car Lovers :)
Alain
cit-rotti
x 78
Re: C5 2.0HDI 07, turbocharger fault P0243
Unread post by cit-rotti »
I can't contribute anything to troubleshooting.
DocBackUp and SEDRE can also be installed free of charge on Virtual-Box if the conditions of virtualisation are given.
The link can be found in the German ACC Forum by "René Mansveld".
https://www.andre-citroen-club.de/forum ... tallieren/
It is important not to translate the password and login, but to enter them in "German" as in the link.
Login = "webseite"
Kennwort = "zeigen"
Greetings Wolfgang
x 6947
..just be aware that they will be 10 years out of date, especially for parts.
cit-rotti
x 78
GiveMeABreak wrote: 29 Jun 2023, 11:23 ..just be aware that they will be 10 years out of date, especially for parts.
Correct - the spare parts list can be used with caution - the correct spare parts can only be determined via the current Service Hotline.
On the other hand, the repair instructions/electrical circuit diagrams/repair times are often very helpful - these were also almost always transferred unchanged to the current Service Hotline - and they are free of charge.
Greetings Wolfgang
toolfan
x 3
Thank you guys!
toolfan
x 3
I probably found the fault: I replaced the plug which connects the turbo pressure controller to the wiring harness of the engine. Since then, a few hundred kms in two weeks, no problems any more. I hope it lasts...
https://www.ebay.de/itm/165876251654?mk ... media=COPY
