Hi, it's been a while, the old V6 has been hiding in the shed for far far to long. So time for some resurrection.
I have it running and rising which is a start it has several low pressure lhm leaks but that's for another day.
Basically it gets warm, I mean hot, fan kicks in top hose is pretty warm, rad and bottom hose are cold, heater gets pretty warm. In conclusion I don't think the thermostat is opening.
Had a look online found a guide for removing the stat housing on a 406 V6 (looks the same?)
I've removed the 5 bolts that seem to hold it on, removed the hoses off either end, got wet feet, removed various pipe clamps so is should have clearance.
I've rocked it back and forth leavered it in and out, it moves quite a bit.... But can I get the ruddy thing off! Am I missing something? Open to tips hints suggestions or do I just need to be more brutal.
Thanks Dunk
Xantia V6 thermostat housing won't come off.
dunk
Needed something sensible whilst the 2cv is off the road.
'97 S1 Xantia V6 Exclusive, Grey
'86 Pink 2cv with a Germanic twist
'74 Dyane 6, Rio Red
'75 Random Green Mehari
- x 8457
Re: Xantia V6 thermostat housing won't come off.
I'm desperately trying to remember now. I know I've had them off in the past easily enough.. I'm thinking the thermostat may be all gummed up and causing it.
If you continue to struggle, I'm quite near a V6 engine where I currently am and also near a person who may know. We may be able, between us, to advise further...
- x 1484
Wow! If I am not mistaken, that is my old car. I assumed that it was long gone.
I still think that was the best Xantia V6, and I have owned 4 of them. I do realise that it is no spring chicken, and has accumulated a few niggling faults over the years.
If you have the housing loose, then it just pulls straight off. The body of the thermostat slides through a seal, so you need to make a straight pull until it is out.
I do have to say that I doubt that there is anything wrong with the thermostat, they very rarely fail. I changed the thermostat on that car in 2004 at about 60000 miles in the mistaken belief that it was running too cool.
Michel
It is your (and mine, and Chris Citroenmad) old car. I sold it to Dunk, must have been... 10 years ago now? I'm well impressed to see it's still going! It was an excellent one..xantia_v6 wrote: 28 Jun 2023, 06:57 Wow! If I am not mistaken, that is my old car. I assumed that it was long gone.
Michel
This is the V6 I came to collect from Chris at yours Jim, with DickieG when he sold his HDi to Chris. Must have been 2013/14... It's Mike's old one with manual leather and I believe you'd rebuilt the gearbox.CitroJim wrote: 28 Jun 2023, 06:37 I'm desperately trying to remember now. I know I've had them off in the past easily enough.. I'm thinking the thermostat may be all gummed up and causing it.
- x 8457
Wow, I too am delighted it's still extant
Indeed, it was I who rebuilt the gearbox..
Looking forward to seeing it all good again. I'll bet it's the thermostat rubber seal that's stuck and preventing an easy pull off of the housing....
dunk
It is indeed R252DVC... That apparently everyone has owned
dunk
So in conclusion more brutal with it
- x 1484
But with great care...
- x 5688
Gently brutal!
