Heater blower issue
Cheecore
New User
Heater blower issue
Unread post by Cheecore »
Hey folks been reading through, issue I have is my interior heater blower keeps cutting out when I go past speed 2! The air then pulses out then stops and you can hear a whining noise until you turn fans completely off…after a few minutes you can switch it back on….it sometimes stays on at speed 2 but anything else it just does the above? Any ideas!? I’ve just changed resistor and still doing it?
Cheers folks
darbuck
x 289
Re: Heater blower issue
Unread post by darbuck »
It sounds like the fan itself is kaput, you will need to replace it
Darren
x 1939
Unread post by Paul-R »
What do you mean by the resistor? Do you have a photo?
darbuck
x 289
I think he means the control resistor Paul, which is screwed into the fan housing. It controls motor speed as per the switch position. The fact it is making a whining noise would indicate the motor is gone.
Darren
x 1939
I was wondering whether it might be possible that he replaced the heating resistor(s) by mistake and the control unit is still faulty.
MH123456
x 6
Unread post by MH123456 »
+1 for the motor. Did the same with my Pug Partner - resistor replacement didn't resolve it and going over bumps would stop the fan. Stopping and starting would work sometimes, but was getting worse. Replaced the blower motor and all working brilliantly since.
A long time is a lifetime and a lifetime's too short
x 1072
Unread post by Rp0thejester »
Well there you go, if it happens on bumps it's an electrical issue. I always think that. If it doesn't do it when stationary its most likely electrical
darbuck
x 289
Electrical issues more often than not are due to a broken winding or in the case of a motor bad brushes unless it's a brushless of course a bump can knock a connector loose though, I am having a problem with an airbag connection coming loose when I hit a bump in one of my other cars.
Darren
