Citroen Xantia 2.0 16v coolant
GLITCHD
Unread post by GLITCHD »
Hi!
What is the correct coolant for this engine? When i search up on the car i get multiple different coolants. The colour of the coolant is no longer possible to see as the car has had mostly universal coolant put in it.
x 8422
Re: Citroen Xantia 2.0 16v coolant
The correct stuff will be ordinary old-school ethylene glycol.
In case it's had some other brew in there in the past, give it a really good flush. A good idea anyway if things are so mucky you can't see the colour of the old.
Colour is not a good guide to type but do be aware that different types should never be mixed. Doing so can result in serious problems.
