Hub/axle nut size 2010 citroen grand picasso p
Ashp
Unread post by Ashp »
Does anyone know what size socket I need for the axle nut on a 2010 citroen grand picasso please
x 1496
Re: Hub/axle nut size 2010 citroen grand picasso p
35mm - Citroen have been using this size for ever! In most cases a 36mm will suffice if you have one which is more common - they're not (supposed to be) that tight - only about 240lb ft.
