DS5 window/handbrake cluster changed, now the hand brake shows a fault and won’t operate correctly
PaulMac844
Unread post by PaulMac844 »
Hi all, just changed the window / handbrake control cluster, now the handbrake is showing a fault and won’t work properly…… please help :( :(
x 6945
Re: DS5 window/handbrake cluster changed, now the hand brake shows a fault and won’t operate correctly
You'll really need to either retrace your steps and did you first disconnect the battery before you replaced the module following the (BSI Reset / Battery Disconnect / Reconnect Procedure)? The circuit is live all the time, so always follow this procedure when replacing electrical components.
If there is nothing obvious and you've not disturbed any wiring in there, then you'll need to provide us with some fault codes that will be triggered with this sort of error (and be aware that a generic fault code reader may not pick up all the faults - especially constructor-specific ones.
