Help with citroen relay central locking woes.
R1ch1e
Unread post by R1ch1e »
I have a 2014 citroen relay enterprise. The back van door central locking doesn't work, i bought the van with it not working. I have put a new actuator in which didnt help, i probed the wiring loom through the door and found 2 wires with a lack of continuity so i have replaced them but it still wont work.
Any ideas what to try next? Could i just run wires direct to the sliding door as that works fine or do i need a bsi reset following the changes? Wiring diagrams seem to indicate if the side loading works then the back should.
Would the lexia software work for bsi stuff on this van?
x 1077
Re: Help with citroen relay central locking woes.
Unread post by Rp0thejester »
Not sure why you would need a bsi reset, a wire run from the side door should work. As long as it's not a mechanical fault.
