Difference between brake discs
davoxx
x 15
Unread post by davoxx »
What is the difference between OEM 4249.K0 vs 4249.K1 (c5 x7 2008)?
One motorfactor says it's K0, the other says K1.
They have the same specs as far as I can tell, just K0 is heavier?
Is the K1 a newer version?
why?
x 6945
Re: Difference between brake discs
Your parts subs have expired :wink: , so if you want the official part / and alternative Citroen recommended part numbers you'd need to renew your parts subs. But I can tell you that 4249 K1 is not listed as a part for your vehicle.
