The tube popped out after removing the alternator bracket. One of the green o rings has broken off the end of the tube also.
Currently the tube doesn't seem to seal in it's hole, if you apply pressure you feel it going into the hole but it just springs out. There's no snap and fit.
If I have the tube like this and bolt it too it's bracket I fear it will create an air leak.
Could I apply epoxy around the tube to block join to seal it up or does it just need a second green o ring?
I can't find these o rings online either.
Or any other suggestions, it's a real pain to deal with.
