Megane Mk3 AV ports.
ChrisRobin
x 104
Unread post by ChrisRobin »
Hi
I have a early MK3 Megane, if you cast your eyes down toward the gear stick you will see a small panel in the lower dash, as it is an early one it only has AV ports in it behind that useless flap, does anyone know of a "kit" that can be purchased to convert these ports to an SD card reader, the later models have a usb connection in there, mine does not, these ports in the 5 years of ownership have never been used, however my wife has and SD card slot in her 308 and uses it all the time with loads of albums on it and I thought mmm I wouldn't mind some of that, but not sure how to get to "that".
Anyone any ideas?
Just Remember;Where ever you go, There you are !
