Xantia Clarion
This section is for General Enquiries or for Systems not Covered Above
Maxi9130
Xantia Clarion
Unread post by Maxi9130 »
"Bonsoir" everybody:
I've recentlly traded my old Blaupunkt "Nowhereville " for a Clarion PU second hand unit.
The unit works fine but the steering wheel buttons don't work.
Is there any trick for the sincronisation ?
The previous unit worked fine with the sw buttons.
Best regards
x 1429
Re: Xantia Clarion
Unread post by xantia_v6 »
Welcome to the forum!
I assume that the Clarion unit you have fitted is from a later series 2 Xantia?
The series 2 radio is not compatible with the series 1 steering wheel controls, perhaps you can get it working by rewiring the switches in the steering wheel, but I don't think that anyone has successfully done that.
