1922w1 (9804910380) solenoid air vent pipe
508c5
x 4
Unread post by 508c5 »
Hello,
I can't figure out this pipes 2way hookups (i.e. to which ends is it connected) - the relevant drawing doesn't show (at least i can't figure it out) - number 20 part
can someone shed some light ?
Peugeot 508 1.6 156BHP THP VIN NUMBER VF3**************[VIN obfuscated, can be read by forum staff]
x 6955
Re: 1922w1 (9804910380) solenoid air vent pipe
The Top Pipe from the fuel vapour canister (5) takes the vapours to the Purge Canister Solenoid Valve (3) which should be your pipe (20) on your diagram.
Key:
"A" Electrical links
"B" Air inlet
"C" Fuel vapours
"D" Fuel
ReferenceDesignation
(1)Turbocharger
(2)Motorised throttle
(3)Purge canister solenoid valve
(4)Fuel vapour absorber
(5)Canister
(6)Engine ECU
508c5
x 4
thanks, got it, i think . why did they make it so rigid .. :cry:
and why does it have this "fat" part at the tip ? it can't be fitted over a nipple like this..(mine doesn't have it - i think i need to replace it, won't hold up without a clamp/band).
x 1438
Unread post by xantia_v6 »
I think that #20 is the atmospheric pipe for the boost control valve. The knob on the end is a little foam filter with a rubber cap.
When the rubber cap shrinks with age, it can restrict the air flow, causing boost control errors and super-knock error codes.
508c5
x 4
thanks, this foam filter fits over a nipple ? (the rubber end under this filter is supposed to fit over the nipple located on the canister)
x 1438
What cannister? The pipe clips onto the engine top cover (the dotted line in the top diagram).
