I just recently bought 2018, C4 spaceturer 2.0 bluehdi with EAT8 gearbox.
Because it has 150000km, I would like to change oil in gearbox. Can anyone tell me what oil should I use, for this gearbox...
A lot is written on forum for EAT6 gearbox, but nothing for EAT8...
EAT8 gearbox oil change
- x 6946
Re: EAT8 gearbox oil change
You need this oil specifically (AW2 Oil for 8 speed auto transmissions):
https://www.arnoldclarkautoparts.com/pr ... 1635056080
Ozbic1
Thanks For quick response...can you tell which brands got it, because I only found ravenol and aisin and it's not sold hear in Slovenia...any other brands that I missed...
- x 6946
No, that will be for you to source - I can only provide you with the official oil required.
Kopnut
Hi All, can I jump in and ask a question in relation to eat8 gearbox oil, I understand the importance of using the correct spec oil where it counts but with the specific oil for the eat8 ( pn 1635056080) being so expensive, motul have an oil (https://www.opieoils.co.uk/p-90043-motu ... rbox%20Oil).... My query is will this be a good equivalent or stick to the (1635056080) proper one ? ,
- x 6946
You need Aisin AW2 transmission fluid for the EAT 8 or equivalent PSA specification.
Part: 1635056080 as I mentioned above.
- x 1496
Appears there is a Ravenol oil to AW2 spec which is a lot cheaper than the PSA oil: https://www.ravenol-direct.uk/ravenol-a ... fluid.html
Your gearbox, your choice of course!
Kopnut
Thanks RichardW and Givemeabreak, more info to chew over
