Hi. I have a Peugeot 207cc 1.6 HDI GT.
ABS pump failure and I’m struggling to find a replacement part. Car Reg is HJ60 PWU. VIN no. VF3**************[VIN obfuscated, can be read by forum staff]. Original module number 9665899180 - can anybody advise which ABS module is compatible as I cannot find an exact match anywhere online - thanks in advance.
ABS Pump
- x 1056
Re: ABS Pump
The original Peugeot part number was 4541PN then later updated to 4541TF however these numbers probably wont help you if going down the used route as they are not marked on the actual unit anywhere. The number on the unit is normally the (part) manufacturers number. Ideally you want to source one off the same spec & age of car.
