DS3 Wiring ABS
x 6945
DS3 Wiring ABS
If you want a specific diagram, let me know the system (A/C, Electric Windows / Central Locking etc.) and then pop your VIN up. I should then be able to pop you a Hi Res. diagram up here.
Sprenj
Re: Citroen Mechanics Handbooks (see page 1 for listing)
Unread post by Sprenj »
Hi there I'm looking for a wiring diagram for abs pump ,ECU on my ds3 I still don't seem to have found the fault I mentioned in a previous post . My vin VF7**************[VIN obfuscated, can be read by forum staff]. The abs light and esp is stil on and have checked everything that was mentioned. The battery tested ok and checked all the wiring but just need details if you could help please . 👍
x 6945
Here's the ESP Diagram:
7800 is the ESP ECU.
Most codes for the hardware can be found here in hierarchical groups:
https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
