2.0 HDi (RHR) air doser / throttle body
vallium
x 16
Unread post by vallium »
I'm about to clean it as it's seriously crusty & have a few questions before proceeding.
Is there a seal between air doser and intake manifold? Couldn't find it on parts catalogue.
As I understand only electronic parts on it are MAP & air temp sensors (both removable), flap is operated by vacuum. So I can move it without messing something up?
Are there any factory torque values for bolts that fix air doser & both sensors?
x 6945
Re: 2.0 HDi (RHR) air doser / throttle body
I'll need your VIN (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff) before I can check this for you.
vallium
x 16
Hi, VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Thank you
x 6945
Cylinder Head Cover
Air Inlet Manifold Torques (7):
  • Pre-tightening to 0,5 ± 0,1 daN.m
  • Tightening to 0,9 ± 0,1 daN.m
Oil Trap (8)
Tightening Order:
Air Mixer
Inlet Air Meter Torque:
  • Tightening to 0,8 ± 0,2 daN.m
Air Inlet Pressure Sensor (7) & Air Intake Temperature Sensor (8) (No Torques Listed)
vallium
x 16
Thank you again. Update from me:
There's a flat round rubber seal (not o-ring) between air doser and intake manifold that does not appear to be available individually. It looks solid but but I would preferably replace it as there was oily leak at bottom on the outside.
Otherwise it was cleaner than expected only IAT sensor was completely caked in mix of EGR & turbo oil crap. No codes, but it couldn't do it any favours. Unfortunately I forgot to measure resistance before cleaning.
BitZone9
New User
Unread post by BitZone9 »
GiveMeABreak wrote: 27 May 2023, 13:54 Cylinder Head Cover
Oil Trap (8)
Tightening Order:
The attachment Vall Cyl Head Cover Tight Order.PNG is no longer available
Air Mixer
The attachment vall air doser.PNG is no longer available
The attachment Val Map Ait Inlet.PNG is no longer available
I apologize in advance for digging up this topic, but could someone provide me with the tightening order and the respective tightening torque for the camshaft cover?
Thank you very much.
vallium
x 16
vallium wrote: 27 May 2023, 15:34There's a flat round rubber seal (not o-ring) between air doser and intake manifold that does not appear to be available individually. It looks solid but but I would preferably replace it as there was oily leak at bottom on the outside.
Part is available as VOLVO 30650790, I bought a copy Elring 341.100.
At first it seems it's too large but there are detentes in round hole that make it go squiggly and take up the additional length. Just massage it in.
It also projects about 2mm away from plastics while old one was practically level with it.
scourgtheking
Unread post by scourgtheking »
vallium wrote: 26 Jun 2025, 14:19
Thank you so much ... i was searching for this damn gasket for more then a week. i just started cross-referencing other DW10 cars and found this (Elring 341.100) on a Ford Mondeo IV and was very relieved to find your post saying it fits! I hope this fixes my last air (&oil) leak.
