Window Blinds
HuggyBear1
Window Blinds
Unread post by HuggyBear1 »
Hello
I have a 2022 Pug 5008: I’ve seen a picture of window blinds in the rear which are built into the door (the door card has the panel on currently appearing to cover where they would go)
I can’t for the life of me find them anywhere, the only ones available are those that fit around the trim of the window meaning you can’t open it if required.
Do they exist? Or am I dreaming?
Ps sorry if in the wrong thread…. first timer and found it quite difficult to navigate on mobile.
Cheers
x 6954
Re: Window Blinds
The in-built rear side door blinds are part of a specific trim level, so would only have been available as a factory-fitted option when the car was ordered.
You can't retro-fit the factory-fitted versions, so will have to settle for the flexible / removable option provided by Peugeot or an aftermarket type of stick on roller blind or similar.
